Zum Hauptinhalt wechseln
Why its not have master reset as like press and hold the power button
How can I disable the &&^&^$^ safe mode
I had try all method and trick but it's not working how can I disable it
I all ready have factory data reset
But the safe mode is not removed so please help hurry
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The safe mode generally happens when the buttons for power or volume up or down are stuck or damaged. So the phone goes into safe mode cause it gets a signal that the buttons are being pressed.
You can try firmly tapping the side of the device were the buttons are located to see if it's a mechanical failure that you can loosen the button back to the unpressed position but often times it requires replacement of the switch under the buttons to fix.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
asif wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 18
