Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
How to dismantle MBP and clean the keyboard backlight after spill?
I spilled some coffee on my two weeks old MBP. It has dried and everything works, the only problem is that the keyboard backlight is strong just in the center of the keyboard (under TYUGHBN keys) and fades toward sides.
I think that it's caused by the coffee preventing the light from coming through the keyboard. Here is a similar problem described on an older model - Keyboard backlight only glows in center
It seems to be necessary to remove and clean the layers of plastic placed between the keyboard and the backlight diods. I've purchased some tools from ifixit and will try to do it myself. Any hints and suggestions will be very much appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here's the guide you need to follow: MacBook Pro (13 Zoll, Mitte 2010, Unibody) oberes Gehäuse tauschen
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Thank you! Any recommendations regarding the cleaning part?
von
It's according to what was in the coffee. I've cleaned parts using distilled water and it works fine if given the time to dry correctly.
von
There was only a little bit of milk in the coffee.
von
Look for the liquid submersion indicators that may have turned red. They will tell you if an area has gotten wet and needs cleaning.
von
Is the same guide relevant for a late 2011 MBP?
Bewertung 0
Antwort hinzufügen
jakub wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 12,529
