Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und seit dem 19. September 2014 auf dem Markt.
4723 Fragen Alle anzeigen
No service after two lightning connector assembly replacements
Hi,
Recently I got job to replace a iPhone 6 lightning connector assembly due to a bad lightning connector. After the replacement it had no service and would not work even if I restored it from iTunes. I thought I might have been careless with the antenna cable, so I replaced the assembly with another brand new one and everything seemed to work after another restore through iTunes. Two days later I receive the phone back from the customer and again it has no service. Reconnecting the cable does not yield any results and neither does a dfu restore through iTunes
Does anyone have any experience with these types of issues?
Could the issue be motherboard related, or was I just unlucky and installed two faulty parts?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
iPhone Akku Fix Kits
Nur $29.99
Buy Now
Nur $29.99
Buy Now
1 Antwort
Gewählte Lösung
Using JBL replacement aftermarket charging ports? You will be having a bad time with them because there are quite a few that end up being faulty with the 3G / 4G reception switching.
You are most likely unlucky and installed two faulty parts.
I recommend trying to get the apple logo'd charging ports, they IMO are better in quality especially when it comes to this issue.
War diese Antwort hilfreich?
Punktzahl 3
Kommentare:
I will try that, hope I am just unlucky
von
Antwort hinzufügen
Ole Sivert wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 62
