Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Touch ID doesn't work after screen replacement
I recently did a screen replacement full with digitizer, sadly after doing this the touch ID in my iPhone is no longer functional, im using the same motherboard that came with the iPhone so it should be working. The home button does work, I restore the phone, and even changed from digitizer but nothing seems to work. Please someone help me I love Touch ID.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
both the digitizer and home button dont seem damaged at all, but maybe im just looking incorrectly, is there a way to know? Please help.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I'm replying assuming it still works as a home button, clicks and takes you out of an app and back to the home screen, etc. I am also assuming you have double checked your connections, sometimes it's just a pin alignment issue and just need to be unplugged and plugged back in. If you have tried all of those things and still no luck, sometimes TouchID can be affected if you damage the long flex cable that runs along the metal plate behind the screen, connecting the home button and board. Have you checked it for any nicks or tears? If there is any damage whatsoever, you may need to replace that. Hopefully that is your issue, as it is a simple fix. :)
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Marcelo Marquez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 95
