Home button with water exposure
Dropped my phone in a hot tub at 2 ft for 2-3 seconds. foolishly did not power off and dry out after. now phone states that it cannot activate touch ID. It doesn't say anything about home button needs to be replaced like some error messages ive seen. Is there any troubleshooting I can do other than restore and check all the connections inside? Apple wont recalibrate the home button to the device since the moisture sensors reacted. I have the virtual home button up just want to see if there's any other steps I can try. can a new home button be installed without the touch ID feature?
Ist dies eine gute Frage?
2 Kommentare
When I open my phone and check internal components. would it be helpful to clean connections with isopropyl alcohol or will that likely cause more damage? Ive repaired iphones prior to the touch id sensor this situation is unique to me. anything I should keep an eye out for other than scorched components or circuits?
von Brett
Upon opening the phone I noticed arc damage near the smaller of the two lower display connectors. Can anyone confirm which connector sends home button encryption info? Wondering if switching the display out may fix my problem. No signs of damage to the home button components just this one connector.
von Brett
