Zum Hauptinhalt wechseln
Die PowerBeats2 Wireless Headphones by Dr. Dre sind In-Ear-Kopfhörer, die für aktive Nutzer entwickelt wurden.
Headphones were washed and won't work!
How to fix washed headphones so they work again, if possible?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It's not surprising that your headphones do not work after washing. Did you dip them in water or just wiped them with a wet cloth? In any case, if water has entered the headphones and you can dismantle the covers, etc. check whether you can find wet parts. If you find water inside any place wipe it carefully with a dry cloth or paper napkins and leave them open to dry in the air. If this was the cause they should work once you put them back together. Of course there is always the chance that the water may have shorted and burnt some components in which case send them to the service facility or buy yourself a new pair (it may be cheaper than having them repaired). Oh, don't forget to check the batteries too.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
AnTHoNY FuCcI 18 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,777
