My Toro self propelled lawn mower starts right up and then dies.
My engine starts up and runs for a few seconds and then dies. I've clean my carburetor and took the float bowl off and cleaned it out. The bowl had a small pieces of a gel substance in it. I removed the carb and the float bowl and blew them all out. Also took the float of and needle valve and blew out the carb. I've checked the fuel lines and no cracks. Put it back together and it does the same thing. Any suggestions??
Ist dies eine gute Frage?
4 Kommentare
This just happened to me today, and i've found another solution that has at least worked for me. I kept on pressing the fuel pump button for about 7-10 times every time before starting the lawn mower. The same thing kept on happening, the mower wouldnt run longer than a few seconds, but as i kept doing that eventually it started and now runs as a brand new one. It stayed in the garage for the whole winter so probably it got clogged cause of petrol that was left in the tank, but constantly trying to start it most likely unclogged it. Give it a try ;)
von mr.zitkus
I have a Toro lawn mower, I prime it and it starts up and will mow a 15-20 foot strip and than dies. I prime it again , it starts and can mow a 15-20 foot strip and dies . I can do this over and over what is the problem
von Tony
Same here!! I have tried all the fixes on YouTube...I have no idea what’s wrong but man it’s getting frustrated. Anyone have a fix?
von screaman005
Hey Tony, I just found this video. Not sure if it’s my problem or not but I haven’t seen anything like it yet. Hopefully it helps your situation. Going to try mine now.
https://youtu.be/xCzzKnX-sTQ
von screaman005
