Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 will not charge with certain chargers
I have an iPhone 6 that's being very picky with chargers. I have one OEM Apple lightning connector that charges the phone fine. However, it refuses to charge when connected to anything not OEM. We've tried 3 aftermarket chargers and the phone will not even show the red battery on the screen. The port on the iPhone 6 port is cleaned and free from lint and debris. The same aftermarket chargers work fine on my 7 Plus so the chargers are not broken. Any ideas why it would have this issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare
this helped a lot because my phone does the exact same thing i gotta use chargers from 5 and below in columbia its very picky with chargers
von
My iPhone 6S will only charge with an iPhone block
von
Iphone 6+ will not charge from USB device charge port on KTM 690 SMCR 2022 motorcycle. I am using an OEM Apple cable and other devices will charge from this port.
von
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Apple released a standard for charging accessories called "Made for iPhone". You'll often see this logo on packages when you shop for accessories. Specifically, this standard ensures there's a chip in the cable that stops a power surge (in basic terms) from blowing out components on your phone. Repair shops are being inundated with repairs for the U2 Tristar chip that gets damaged when using aftermarket, cheap cables.
https://developer.apple.com/programs/mfi...
You can still buy a non-OEM cable however it must be "Certified Made for iPhone (MFi)". This chip costs about $3 to manufacture, so any dealer selling you a cable for less than $5 is probably selling you cheap knockoffs that will ruin your phone.
For what it's worth, iFixit sells certified charging cables at a reasonable price here: Lightning to USB Charging Cable
Lightning to USB Charging Cable Bild
Produkt
$9.99
War diese Antwort hilfreich?
Bewertung 2
8 Kommentare:
Okay, I'll try that. It's for someone I know and the cable she bought was $30 (From what she tells me), surprised to see that they charge that much and it's not MFi?
von
That is surprising. But high cost doesn't always equal quality. My hunch is someone made out on that sale by selling a super cheap charger at many times its worth.
von
That doesn’t explain though why the same charger cable that won’t work on my iphone will work on my son’s or wife’s who have the same model or later than mine.
von
My problem is different and NO ONE yet can figure it out. I can NOT charge my phone with any chargers made by Apple. I've tried 11 (3 I have, family and friend's). No matter what cord I use, it will not charge with an Apple white charging block. It will charge with several of the aftermarket 2 outlet chargers (regardless of the cable being Apple or aftermarket), it will charge with SOME USBs (20 % of the ones I've tried), it will not charge in my Sentra's USB but will in my Ram USB with the same cord. It will charge with my laptop, but not my wife's laptop. I even walked by an HP printer in a hotel and it would charge by the USB port on the printer, but not the computer or wall USB port right next to it (with the same cord). This problem is only 2 days old on a 2 year old phone. Apple can't figure it out and I can't find anything online about it!
von
my phone is the same way i have to turn it off plug the charger in and when it powers on it will be charging buy only then with certain plugs and cords
von
3 weitere Kommentare anzeigen
Same problem. My phone stopped charging with a number of chargers, ALL said they were made for iPhone - the last one I even bought AT the Apple store. Someone gave me a cheap knockoff charger and it worked, it was great - then my rabbit chewed through it last night, and again none of my other, certified cables will charge the %#*@ thing. Never had this problem with androids, and it’s obviously not the port as the one charger did work.
Bewertung 1
4 Kommentare:
Did you manage to fix it? I have the same problem... Only this cheap (free actually!) Cable that I got from some advertisment will charge the phone... I'm terrified of it breaking
von
von
I noticed it started doing that after I upgraded. I Believe that there is a bug however slight in the upgrade that has not been detected or identified officially. Because when I upgraded again it went away as though it was never there. They’re making these products too fast they need to dig up jobs again. He was meticulous.
von
Read an article a while ago that said there has to be a certain amount of resistance between some of the pins on the cable or Apple devices will not charge and you’ll sometimes get the message that the device is not compatible even though it is.
So I’ve used combination of Apple cables non-Apple cables and different charging devices. iPhone three will not charge but iPhone 4 does. iPhone six and 8 won’t charge unless it’s got a Apple certified cable on one device but charges fine on other usb chargers with non apple cables.
I can charge my iPad and my iPod 5G on charge ports which the iPhone 6 and eight and three won’t work on but 4 will.
What article says on what pins you need to have a certain amount of resistance in order for it to work with Apple devices. maybe somebody else can find it.
On one USB charger iPhone 6 and eight won’t work but I can plug them into another USB port with a non-Apple cable and it works.
von
Hi, I have an apple 5 it can't charge, when I put on charger its become on ong off like the bettery is very low but do not come on, it can be this new charger I have or it chooses chargers?
Bewertung 0
I have same prob… it will charge overnight if left plugged in but takes that many hours for full charge I don’t get it either and can’t find a answer online
Bewertung 0
Usually this is worn out charging socket pins.
To fix that you need to get the charging port replaced.
Worst case scenario it would be a charging chip replacement.
Bewertung 0
2 Kommentare:
I bought another cable and it works with that one. I don’t understand how it would be a physical problem with the phone when it charges fine with some cords but not others?
von
@rabbitbinks This is due to contact surface area. Your pins in charging port from factory are perfectly gold plated. Your charging wire from factory will be perfectly gold plated.
Over time the gold plating gets scraped off with the friction of pushing together and pulling apart the connectors.
The pins in the phone jack are sprung and can over time sit slightly off centre and so the contact area is lower on top of worn gold plating.
To top it off the pins also go dull because of contaminants like oil from your fingers, dust and lint getting into the charger port, any liquid settling on the pins say if you left your phone on a counter when you shower or cook and then there is outdoor weather like rain or mist or just general humidity.
If you have a microscope use a non-metallic implement to lift out as much dust and lint as possible. If you have dental brushes used in place of floss, you can possible brush debris from the pins in the port.
Use an eraser and/or a fibreglass pencil for the cable pins.
von
I had an Android, (Moto e4 plus), that had the same issue. It wouldn't charge one day with either of my charging cables. Then I went to the phone shop, and he gave me a Samsung charging cable. That worked, yeah, it's something about the quality.
Bewertung 0
I have the same issue right now. I had issues charging my iPhone 6 just this week after I transferred to my iPhone 13. I still want to use the my 6. None of my lightning chargers fit the port. The SAME exact chargers that were working before the transfer last Saturday. How could they fit on Saturday during my transfer and now none of my chargers work?
Bewertung 0
Antwort hinzufügen
Austin Ledet wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 76
Insgesamt: 47,437
