Memory Card Slot 1 & Controller Port 2 Not Working
I just recently fixed my PS2's internal ribbon cable connections, only to discover that now controller port 2 and memory card slot 1 aren't working. However, memory card slot 2 and controller port 1 are working fine.
I tried pulling up the pins on the slot so they'll come in contact with the card, but it's still not able to read it.
My system is an SCPH-39001
Had it since 2002, then it stopped working in 2009, finally got to fixing it and it's 2017.
Update [17 Aug 2017]: Some or more of the pins on the module for the ribbon cable seems to be slightly bent out of place now
Update [6 Sep 2017]: Got a new ribbon cable and controller ports & memory card slots module. Still can't get them to work, but the contacts seem to be working fine from the board to the cable to the module.
Ist dies eine gute Frage?
1 Kommentar
"Update [17 Aug 2017]: Some or more of the pins on the module for the ribbon cable seems to be slightly bent out of place now'
So that does it, right? If those pins are bent it means that by changing the module you will solve your problem??
von Alex Niculescu
