Zum Hauptinhalt wechseln
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
78 Fragen Alle anzeigen
How do I remove dust particles on top of the LCD screen?
How can I disassemble the device to clean the LCD screen?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It's fairly easy to remove the screen protector, just be careful not to get any glue on the LCD I accidentally did and I permanently dirtied up my screen even more.
Anyways, supplies needed:
  • Microfiber cloth
  • Suction cup
  • Reasonably strong glue (optional)
Instructions:
  • Orient your calculator with the screen facing up.
  • There's adhesive holding the screen protector onto the main case. You may want to heat it up, but it's fairly weak so you may be able to get by without doing that.
  • Take a strong suction cup and place it directly on the screen. Pull up until the screen protector comes off.
  • Take a microfiber cloth and, making sure it never touches any glue, wipe off the dust.
  • Now take the microfiber cloth and wipe off the inner part of the screen protector. When you're finished, don't let the same microfiber cloth touch the LCD.
  • When you're done, carefully inspect the screen to make sure nothing got on it. Then put the plastic screen protector back in place. You may want to replace the adhesive with something stronger so dust never gets in it again. I used superglue but I don't recommend you use that in case you ever need to take the screen off.
I hope that helped!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I tried this as well and also got some glue on the inside of the screen protector. I even tried acetone to remove it and the stuff wouldn't come off (this glue being the factory one). Really wish I'd been more careful when cleaning the old glue off *sigh*.
von
Antwort hinzufügen
Mark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 72
Insgesamt: 2,145
