Zum Hauptinhalt wechseln
Modell A1418 / Ende 2013 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
254 Fragen Alle anzeigen
Possible causes in vertical lines of LCD
A few days ago I tried to increase the memory of two iMac's, from 8GB to 16GB, using memory with factory specifications.
In the first everything turned out as expected, however, in the second, after making the change, the LCD screen showed two vertical lines since the system started. I replaced the original memories and the problem persists, have I damaged any components?
Which component could have been damaged? Thank you very much for your comments and suggestions.
Actualización (24/08/17)
This is how look
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@joepep post some pictures of what your display shows with your question. That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@joepep - Jose I've got some bad news here ;-{ When you tried opening your system without using the correct tools and technique you damaged the LCD displays fragile wiring. Sadly, this is not repairable. You'll need to replace it with a new screen: iMac 21.5" Display LCD Assembly, Late 2012 / Late 2013
Here is the proper IFIXIT guide to follow: iMac Intel 21.5" EMC 2638 Display Replacement
And the needed tools:
And you'll need at least one set of adhesive strips: iMac Intel 21.5" (2012-2017) Adhesive Strips
Plastic Cards Bild
Produkt
Plastic Cards
$2.99
iFixit Opening Picks (Set of 6) Bild
Produkt
iMac Opening Wheel Bild
Produkt
iMac Opening Wheel
$7.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jose Neftali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 629
