Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Reparaturanleitungen für Fahrzeuge der Marke Volkswagen
313 Fragen Alle anzeigen
Car loses power while driving - 3 shops and nobody can fix it
Hi, I'm hoping someone will be able to help as I'm running out of options. I have a 2009 VW CC and have had some major issues with it. My goal is to keep it for another 10 months before I move back to the States, currently in Abu Dhabi...
I have had some electrical issue with the car i.e. lights going out, trunk not opening (due to false positive) and now the car loses power all the time while driving in the city. When I drive around 20-60 mph the check engine light comes on and the car loses its power shortly after that and I'm unable to accelerate at all. Even if I floor the gas peddle, it won't go over 2K RPM. If I'm lucky, I'll be able to keep the speed but most of the time it decelerates on me. Once this happens, I have to shut the engine off and start it back up while driving, as I don't have the time/power to get to a safe place to stop. While driving today, I had to re-start the car 5 times on a 15 minute drive. Once I get up in speed and I'm driving on the highway, I don't have any issues, it's the city driving that's causing these issues.
I had it in three different shops here in Abu Dhabi and they have been no help. So far, they have replaced the throttle relay, fuel relay, throttle assembly, cleaned the fuel pump and some other stuff I can't remember.
The car takes super and is a 6 speed stick shift.
Any advice would be greatly appreciated.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
2 Antworten
I had the same problem but with my 2003 Vw bora, it ended up being the Coil packs.
So I got them all replaced and new spark plugs
War diese Antwort hilfreich?
Bewertung 0
I would ensure that your ground connection from the battery is proper as a first step. My friend had an issue where his car would straight shut off when he turned the wheel at idle. Bad ground connection.
Bewertung 0
Antwort hinzufügen
Josh wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 247
