I have an Echo SRM 225 Trimmer. Full disclosure I left the fuel in it all winter. When I started the season it would start then quit, but re-start at a later point. At some point it just stopped starting. I took the following steps:
*Emptied the gas tank and put clean fuel in
*Cleaned the Carb with Carb Cleaning Fluid
*Replaced the air filter and spark plug
*Replaced the fuel line system
*Finally replaced the carb
It still won't start. Any idea of what else could be wrong?
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Do a compression test on the cylinder . Odds are when you were running the machine with a plugged carb you had a lean burn condition and as such didn't have the proper amount of fuel going into the cylinder which can cause the cylinder head to burn . The fuel acts as a cooling agent for the engine and if theres not enough fuel in the cylinder it doesn't get the cooling it needs . If the cylinder head is burnt you wont have proper compression. Hope this helps
2 Kommentare:
One other thing to check is the in tank filter may be clogged with green goo from old gas
2 Kommentare:
I have a Ryobi 4stroke still running strong after 20 years. ECHO 2 stroke ran fine when new 1st bought. Next year it will start and give up. If you let it sit it does that until your arm falls off pulling.
1 Kommentar
thank you! I will look at that.
von Mary Wood
