Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 with no image after screen replacement
I've been fixing iPhones for a while now with no problem. This time that I fixed it for a friend i replaced it with no problem it turned on and everything and about a week later the phone just went black but it is recognized when I connect it to iTunes. Could it be the logic board that was damaged? The phone has never been wet either.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Have you checked the connector on the logic board? Check whether it is in good condition and clean it with Alcohol cleaning fluid to have a try.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I will try this thank you
von
After trying this multiple times it finally worked
von
Can you verify if it's no image or no backlight? Try shining a light on the screen and see if you can see anything. If so, it could be a problem with your backlight circuit.
Bewertung 1
1 Kommentar:
There was light at first looked kind of purple but then just went out
von
This happend to me but on a different phone. The screen is broken talk with your seller
Bewertung 0
1 Kommentar:
I thought it might be that too but i tried 3 different screens and one original that just had a crack
von
how you fixed your problem? please tell me, I have same problem
Bewertung 0
Antwort hinzufügen
Alex wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 562
