Zum Hauptinhalt wechseln
Das iPad der 5. Generation kam im März 2017 auf den Markt. Es ist mit WLAN und LTE mit 32 und 128 GB Speicheroptionen erhältlich. Es verfügt über ein 9,7" Retina Display und einen 64-bit A9 Prozessor.
Why won't the home button work after screen replacement?
I replaced the screen on this iPad generation 5, The replacement went well, as well as an iPad repair can go, but now that I am testing it, the home button won't respond. The digitizer is working great and everything else is cool. The home button's cable is not bent, nor does it appear damaged. Has anyone experienced this issue with the 5? I really hate repairing iPads, this might be the last one for me.
Update (08/26/2017)
I wasn't able to. The broken glass shredded the cable. I think that's the problem. I know the fingerprint won't work, but the button should, shouldn't it? Where can I purchase a home button for an iPad 5?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
did you use the original home button? swap from the broken screen
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
We don't sell that iPad 5 button on iFixit yet, but we're working on it.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
That's cool. I have found one to purchase. I'll replace it and let everyone know the outcome. Hoping this replacement will do the trick.
von
We should have these up in the store in a couple weeks. The touch ID will not work if it's replaced with anything other than the original home button but the regular home button "clicking" functionality will still work when replaced.
von
Do the home buttons for the iPad 5 that you have for sale on this website work except for the touch ID? Has there been any progress Scott since your last post on 08/28/2017?
von
Hi, Cheryl. I was able to use the replacement button with no problems except the obvious lack of touch ID. I must admit, it hurts my heart to repair a device knowing that a function will no longer work, but the customer was just happy everything else did work.
von
Antwort hinzufügen
Shawn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 6,251
