Zum Hauptinhalt wechseln
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
Why is my button (number 9) not functional is there something broken?
For some weird reason my button (number 9) has stopped working for the first time in 8 Years is there something broken that I can Fix or/Replace if possible please assist me on what to do
Thank you
Kind Regards
Christo Els
From South Africa
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If this calculator is very old and dirty, the contact points on the board might need cleaning. This may be hard to do depending on the calculator, but you will want to unscrew the back of the cover, and use a jimmy tool to pry into the case. Move the jimmy all around the edges of if until it pops off. Take out the board. There will be a very large ribbon cable like thing with a bunch of wires running through it. You are going to want to take high concentration isopropyl alcohol (I'd recommend 90%) and clean the large ribbon cable on the side that touches the buttons. Reverse the disassembly steps to put it back together and you should be done with the repair. The case will just click back together.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Christo Els wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 31
Insgesamt: 182
