Zum Hauptinhalt wechseln
Model CUH-ZCT1. Dieser Sechsachsen-Controller mit dem 3,7 V Lithium Akku, den Sony im November 2013 auf den Markt brachte, ist leicht zu reparieren. (BEACHTE: Die Teardown-Anleitung ist NICHT für dieses Modell)
Why is my r2 button not working
My r2 button wont work right I have to press it really hard in Battle feild wont work in gta5 .
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 10
2 Kommentare
Chk the rubber on L buttons if ok!.
May need some control setting on call of duty. Shooting button response fast/slow
Hope this answer fix your prob.
von
I recently brought this PS4 controller on Amazon and now it’s not working on R2.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Dont know of this helps or not but…. If your controllers get dropped regularly, like mine do…..take it apart, carefully clean the contacts of the conductive film and it's respective contacts on the circuit board. I use 90%+ isopropyl alcohol and a few Q-tips. Scrub, but carefully. Then use a clean cloth to buff the film contacts and the board contacts. Make sure everything aligns correctly when you screw the circuit board back down. Screw the circuit board back down and connect the battery and try it out. Unless your controller is physically broken, or the rubber pads are torn or crushed, this should fix your problem. Unless it was submerged in fluids, just smashed to !&&*, or a button was physically broken from being to rough….this had fixed every single one I've come across with a “shoulder buttons worked and now they don't “ scenario. It's almost always that film. It moves and that was a design flaw.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Do you have any tips for the R2 activating when you're not pressing the trigger?
von
You could also switch the triggers to the bumpers (in the accessibility menu)if you dont want to break your controler or if you dont know how to work with the components (like me)
von
Mind does work but in assassin's Creed 4 he will only jog so it thinks it's not being pushed down all the way
von
Hilfreichste Antwort
Could be a number of issues: the plunger on the inside of the button could be cracked, the button switch could be loose, or there could be dirt or damage to the button switch. Gonna have to open it up and have a look.
DualShock 4 (CUH-ZCT1U) Tasten tauschen
Bewertung 4
Here’s a simple solution to fix buttons that don’t seem to be working. It does requiring taking the controller apart.
https://www.youtube.com/watch?v=Lx3La8a1...
Bewertung 1
1 Kommentar:
Dude I logged in just to say thanks lol this link helped me big time. Just managed to fix my controller
von
How do i fix my r2 button to shoot without pulling it apart
Bewertung 0
3 Kommentare:
Blow air into it with ur mouth worked for me
von
Did not worked for me lol ear me out if there is another solution to repair it whitout pulling it apart
von
Coby Roberds that actually worked, thank you
von
Antwort hinzufügen
Lane Bauer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 25
Letzte 7 Tage: 119
Letzte 30 Tage: 529
Insgesamt: 164,646
