Zum Hauptinhalt wechseln
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52 Fragen Alle anzeigen
I have a totally stripped screw on the body that won't come out
Trying to self-repair my busted T3i SD card port but one of the screws that is right under the battery door of the camera is completely stripped so I can't get inside of the camera. Its deep in the hole so I can't use any sort of dremel, plus the rubber band/super glue trick was not successful. The screw is very small and the strip has become a complete circle. Any help would appreciated! Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
You could try using a drill with a very fine tip. Just drill into the screw until the head becomes separate from the rest; then applying some force, separate the two parts.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Sahil Kumar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 859
