Zum Hauptinhalt wechseln
Ein Samsung Smartphone, erschienen im Januar 2016. Modell SM-J320
48 Fragen Alle anzeigen
Why does my Samsung Galaxy J3 turn green on half of the screen?
I dropped a glass onto the back of my phone and now when i turn it on half of the screen is green/black and the other half is dimmed, is there a possible fix for said scenario?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It may possibly be that the connector to the digitizer was loosened by the contact or it could be that you damaged the digitizer with the contact. I would probably take it to a place for replacement or to check the connection or you can tear it apart yourself. I personally would attempt to do a tear down on it and check the connection first it will save you some money if it is just the connection. But sounds like it is a bad digitizer. It is replaceable you will just need to do some research on finding the part for the replacement.
Hope this helps.... [[ Ungültiger Ersatzteil-Link ]]
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Bogglewogle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,362
