Zum Hauptinhalt wechseln
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Fragen Alle anzeigen
Turns on, does not charge.
Charging port perfect condition. Tried another charging port and battery.
Only shows charging icon at top right of status bar while phone is on for a moment.
Seems like a charging circuit issue but I'm not sure if it's repairable.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This faults actually happen when the charging ic is not working properly.Battery has four connecting pin among them bsi and btemp point is not working trace the track.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks for the answer I was thinking probably charging ic issue, I will trace down the circuit and post results if the charging ic needs to be replaced.
von
Okay, changed PM8843 power management ic, charging now OK!
von
Antwort hinzufügen
Ben wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 839
