Sorry for the late reply, I just saw this.
The most likely solution is a new replacement microphone as small parts such as these tend to have a higher defect rate than replacement screens. However, if the replacement microphone hasn't arrived yet or hasn't solved your problem, I would start by looking at the microphone hole in the housing to see if there is any dust or lint that is causing obstructions. You can clean it with a cotton swab and isopropyl alcohol.
The other thing that could have happened is accidentally prying small components while disconnecting the camera. The camera connector (see Step 49) has several small (tiny) components surrounding it. One of them is critical to the proper operation of the microphone. You will need to do a (preferably magnified) visual inspection of the area. I have highlighted it in the picture below.
Finally, what concerns me is your comment that the iPad has fallen more than once from waist height. iPads, even less than phones, are not meant to be dropped. They are heavier than phones and will hit the ground with much greater force. The surface mount components on the logic board can be damaged from these impacts and occur in unpredictable ways. It is possible that some components were jarred loose or cracked the solder balls/joints.
If there are missing or partially dislodged components or the replacement microphone did not work again, then you will need to have your iPad looked at by an experienced micro-solderer.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
