Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1364 Fragen Alle anzeigen
Ifiixit digitizer screen sometimes does not respond to touch.
Ifixit screen and digitizer replacement sometimes does not respond to touch.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I double checked all screws and connections. The touch works most of the time but acts like it is frozen periodically.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Morning friend,
When you did the replacement did you verify that you put the proper screws in place? I strongly encourage to open the unit again and reinspect your work.
Follow the guide here take note of the screws, disconnect the battery, reseat the cables to ensure they are seated properly, and try again.
If that does not work, there could be an issue with the part. Just ensure that no plastic was left on that part while you open the device.
Hope this helps.
War diese Antwort hilfreich?
Bewertung 1
Hey there!
I recommend talking to our awesome customer service team over on this page if you think the product is defective. If you're worried about troubleshooting, could you let us know more about the intermittency of your issues? Is it a certain spot, or just at certain times? I recommend making sure that your connectors are properly seated as well and that your display bracket hasn't moved anything out of place.
All the best!
Bewertung 0
Antwort hinzufügen
Scott Mitchell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 85
