A1425 Won't Power On After Keyboard Replacement
Hi, everyone! I recently picked up a Retina Macbook Pro 13" a1425 to fix up. When I got it, it would only power on when you plugged in the magsafe and the fans would run on high. Since it wouldn't respond to the keyboard, I assumed some liquid damage on the keyboard.
I purchased a replacement keyboard and just installed it. Now, it doesn't power on when you plug in a magsafe, but it also doesn't power on with the power button. The keyboard does appear to be working though because I can perform an SMC reset (which doesn't help). When the magsafe is plugged in, the light goes from green to amber. It will also go to amber if I unplug the battery.
Anybody have any ideas?
Ist dies eine gute Frage?
1 Kommentar
Update #3: after holding down the power button for ten seconds, then connecting magsafe, it turns on with fans on high like it did before I replaced the keyboard. There is currently no SSD so I connected an external Hd with Sierra on it. I was able to boot into it when I wasn't able to do this before the keyboard replacement. After logging in, there appears to be an x over the battery icon and it says battery not detected. The keyboard and trackpad all work fine so I am ruling those out now.
Anybody know how to fix this or does this mean I have to replace the battery?
von Jon Lewin
