Zum Hauptinhalt wechseln
Model A1236 / 4 oder 8 GB Speicherkapazität
134 Fragen Alle anzeigen
Ipod is dead it wont charge and i cant put songs on it how do i fix it
my Ipod is unrecognized by itunes and therefor it won't charge and i can't reset it. i also can't put songs on it. when i plug it in, it says connect to power and shows the apple sign then shows the front menu then says connect to power how in the world can i fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
mine also same...wat shud i do?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Most likely a bad battery, get a new one here.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
Try a reset. Press centre button and menu. Hold for a few seconds to see if apple comes on screen.
If that doesn't work plug it into a computer via a USB lead to recharge it. Docks and PSU type chargers may not work if it is dead flat.
Update
I am talking from my own experience. I had a dead Nano and it would not charge from a PSU or dock, but did from a computer. Possibly it was because it was not an Apple psu. I would advise anyone with a dead Nano to try recharging from all sources.
Bewertung 0
1 Kommentar:
sbdfhs, you have it reversed. A computer USB output is no less than 4.75 V and no more than 5.25 V and 500mA. It will NOT charge a battery that is below 2.7V You WILL have to use at least an AC charger since the spces on those are Input 100-240V - 0.15A (0.15A) 50-60hz
Output 5V --- 1A So your answer is very misleading. May be an edit would be nice:-)
von
Antwort hinzufügen
tyler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,832
