Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1510 Fragen Alle anzeigen
Avoid dust installing a new screen
Hello
I had to change my Iphone 3G screen after a white screen of death, and everything works fine. The thing is that after the replacement some dust is between the touch screen and the screen. I tried to clean it but without sucess, i cleaned old dust but i get new.
Is there any trick to avoid dust? or maybe a way to remove it, compressed air?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hey there,
A new screen as in the hardware screen or the cover screen that protects your iPhone from your finger prints?
If it is applying the screen to protect the actual screen from your finger prints, there is a website:
http://www.ehow.com/how_5942211_put-scre... (credits to them, I did not write this, although I wish I did =P)
If you're talking about the actual hardware of the iPhone screens: I suggest you take a look at:
http://www.wikihow.com/Fix-an-iPhone-3G-... (If in this case, you want a screen replacement)
iPhone 3G Troubleshooting (Some of the frequent problems that occurred on iPhone)
And there are also some resources about taking the iPhone apart and replacing it with a new screen on the ifixit.com
iPhone 3G Front Panel Replacement
Things you might need to buy:
[verknüpftes Produkt fehlt oder ist deaktiviert: IF137-007-1]
I am sorry I can't actually help out with my current resources, but If I am talking about something totally different, you can re-post your response and I will do some more research about it.
I hope I helped,
thanks!
Nonth =)
War diese Antwort hilfreich?
Bewertung 1
When installing a new screen its best not to remove any protective films untill right before you put it in.
I find that using a microfiber cloth tends to work best.
After wiping it down, keep it covered by the cloth, and then wipe the LCD with the another cloth.
Then (as i said above) give them both a quick wipedown and install them.
By wiping them both right before you close up the iphone you are making the time it takes for dust to accumulate shorter and therefore eliminating most of the dust under the screens.
Hopefully this will prevent any dust getting in, but its not fool proof. Its just alot of trial and error.
Hope this helps!
Bewertung 1
Antwort hinzufügen
krasny oktyabr wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,682
