Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 won't turn on and repeatedly restarts on iTunes
Hello,
iPhone 6 won't turn on and when plugged to PC via USB it keeps restarting so fast that my PC just beeps like everytime I plug/unplug USB.
iPhone doesn't give any signs on screen, just dead. On iTunes first message I can see is that is in recovery mode.
I tried with different cable, tried to clean ports, still nothing.
Like its something faulty with charging port itself(ie. bad connection?)
Any help would be appreciated!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Have you tried a hard reset on the phone? Hold in the home and power buttons. This tends to fix a number of iPhone issues.
von
Einen Kommentar hinzufügen
1 Antwort
i would start doing a hard reset.
if that did didly squat, try placing it into DFU mode and restoring on itunes.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
It won't work. PC just beeps like its connecting/reconnecting.
von
if you know how to open your iphone, disconnet battery for ten seconds, then reconnect. its the best way of sure fire power cycling. at the end, it should be able to go into DFU mode. if not, then i suggest going to your nearest genius bar.
von
Antwort hinzufügen
Vuk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 40
