Zum Hauptinhalt wechseln
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 Fragen Alle anzeigen
When I turn in there is a screen asking for a code. How to enter code?
The screen shows some ok ok line and at the bottom there is firld for 'Code'.
What is code!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@mkh12 I've checked the manuals and I can not see anything that would require you to enter a code. The only code that this camera might show is a fault code. I would suggest that you remove the battery to reset your camera and see what you get. You did not tell us when this code comes up. if ti does so right at start-up or somewhere in the menu. Try to reset your camera by following these steps.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
When I turn on the canera there is a screen on top of the menu options showing the few things:
State: Idle
LogDir: HS00
HsCmd: ok
Hsnet: ok
HTTPc: ok
Code :
What are these?
How tonget rid of this window and goto normal mode?
Is it busted?
Please let me know.
von
that sounds like a diagnostics menu. Let me check the service menu later for. this is a DMC-TZ5?
von
Antwort hinzufügen
Md Kamrul Hasan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 57
