Zum Hauptinhalt wechseln
Apple Watch Series 2, angekündigt am 7. September 2016 und veröffentlicht am 16. September 2016.
132 Fragen Alle anzeigen
Would replacing my screen jeopardise the watch’s waterproof properties
I have a large, deep scratch in the screen of my Apple Watch series 2. It has started to get on my nerves, and I have begun to consider replacing the screen myself. Would replacing the screen cause the watch to no longer be waterproof?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
First it is water resistant not waterproof
https://support.apple.com/en-us/HT205000
If you do the repair, any remaining warranty you have will be kaput.
Replacing it yourself and getting as good a seal as the factory did is unlikely.
The part is out of stock and expensive. I'd call Apple as see what they are charging first.
War diese Antwort hilfreich?
Bewertung 2
There's no way to guarantee that it would still have the same water resistant rating. Also, the replacement adhesive strips I have found so far are a bit thicker than the OEM one. So after you re-set the screen in place, it sticks up a teeny, tiny bit higher than it did originally. Literally, we're talking a fraction of a millimeter, but it is enough to feel. And if you really look closely, you can see the difference too. Does that matter? Maybe, maybe not, but personally, I worry a little bit about the edges of the screens being that much easier to chip.
Personally, before I did anything else, I would try picking up a good screen protector (probably one of the plastic ones like the stuff from Armorsuit, not a tempered glass one) and see if that covers up the scratch enough to not bother you so much.
Bewertung 2
Antwort hinzufügen
Luke Rogers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,205
