Zum Hauptinhalt wechseln
Repair guides and troubleshooting for Acer Predator 17.3" laptops, a group of high-end gaming computers from Acer. These laptops features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
How to disassemble lcd screen? Acer Predator 17.3 (G9-793)
A few days ago, I bought an Acer Predator 17, turned it on, and noticed a problem with lcd display. So, as the laptop has no guaranty, I decided to disassemble the laptop and change the lcd screen with a new one. But couldn't find any screw on the lcd front bezel. How can I open it?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I'm not familiar with that particular laptop, but laptop screens normally have any screws hidden under little sticky rubber pads or disks which you can pry off with a craft knife or just a small flat blade screwdriver. But often there are no screws and you simply insert a spudger or jimmy in the crack between the bezel and the back to release the clips. I've got one of these which is very effective: Jimmy
Handy tool for opening electronics. Bild
Produkt
Jimmy
$7.95
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for your answer.
The bezel seems not having any screw hidden. I'm going to try the second solution and put the result back here.
von
I made a video that may help you out.
https://www.youtube.com/watch?v=4xZo06Gb...
Bewertung 1
Antwort hinzufügen
erfan razi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 1,521
