Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1149 Fragen Alle anzeigen
Don't know if screen broken or something else...
Hello,
I dropped my iphone 3s once and no more images appears in the screen.
Some time later I put it to charge and screen light went on, but it shows only some kind of pixel pattern in grey, with vertical white tin lines.
At this stage I cannot tell what is wrong. Screen seems not cracked, since backlight went on but nothing seems physically broken.
The only thing I can do is to press both buttons at the same time and screen goes black like it turn off. When I turn it on again, I get some weird horizontal lines showing on and off for some seconds, then some color randomly placed lines and then a nice white screen for some seconds before the weird horizontal lines dance begins again, like and old tv with a bad antenna.
I will like to have an opinion in this, in order to know what can I do with it since I hate to trow away stuff that can be fixed.
I took off the screen a little bit and the connector #1, and the screen goes black and you must 'turn on' the phone again. that connector is a little devil, who will umplug itself very easily. But with the connector right on place the problem is the one described.
The others connectors, I didn't remove. They seem well placed.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
coursparis this "some kind of pixel pattern in grey, with vertical white tin lines" is pretty indicative of a broken display. Here are the guides iPhone 3G Repair needed for the repair. To find a replacement display will not be easy or cheap.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
with grey I don't mean lcd liquid, just a degree of very light grey in a perfect pattern. Sometimes is not exactly grey but light blue...
von
coursparis add an image of what your screen displays with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. It will allow us to see what you see.
von
done! thanks!
von
I would advise you to repair phone in a workshop or find the skilled person on this website
von
Nobody? please......
Bewertung 0
Antwort hinzufügen
coursparis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 173
