Zum Hauptinhalt wechseln
Could I put a 2007 logic board in this?
Hey guys,
So my 2006 MacBook Pro has a logic board problem which causes red everywhere that there is black which is super annoying but it goes away when I plug it into a external monitor.
But that’s not the question, so anyway, I was wondering if I could put a 2007 Core 2 Duo logic board into it to replacing the existing Core Duo logic board?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Are you sure you want to put the money into a system which has known GPU issues. You will likely need to swap out other parts as well as Apple altered the display and keyboard subsystems.
This is a money pit I would recommend looking at getting a newer Unibody system (new or used) ideally a i5/i7 model.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks for the input I will most likely get an slightly newer windows laptop as all I was using this for was gaming with windows xp but didn’t want to spend to much extra money if I didn’t have to also is there any way to fix the red lines on black???
von
Sorry no aces up my sleeve here, you need a new GPU chip (new logic board).
von
Antwort hinzufügen
Noah salinas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 50
