Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
Top Case Replacement for A1502 using A1493 Case?
Does anyone know if the MacBook Pro 13 Late 2013 (A1493) Top Case is compatible for the MacBook Pro 13 Mid 2014 (A1502) hardware.
I have come across sites that say they are compatible. However, I see the trackpad trimming for the A1493 is different from the A1502. Also, they are using different cables to attach the trackpad to the Logic Board. I am unsure if the cable will become damaged from the weird trim from the A1493 Top Case.
Update (10/04/2017)
The A1502 uses a different type of connector for the trackpad from what I am seeing. As opposed to the A1493, it is using a slot for the connection. From what i researched, they were considered the same top case.
13" MacBook Pro Early 2015 (A1502)
https://imgur.com/a/cMo9y
13" MacBook Pro Mid 2014 (A1493)
https://imgur.com/a/jnYMk
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Can you clarify what you mean by 'trimming' I don't see any difference between these two cases. the Trackpad cable is routed underneath the battery in both. Are you confusing the 15" model which has the cable going over the battery? As seen here" Trackpad cable over battery
von
Both are A1502 models, 1st one is A1502 2015 (EMC 2835), 2nd is an A1502 2013/2014; A1493 is the battery model number, not the MacBook model number.
These 2 are not cross compatible, they use different trackpads.
von
@krypticcliff Cliff I've updated your post with your images and added the model years. See below for the full explanation.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Cliff - I see where you took a left turn! You have a 2015 model not a 2014!
So in this case you are correct the upper cases are different and require a different trackpad & cable. The 2015 has the cable going over the top of the battery Vs going under it (from the bottom cover viewpoint).
They are different parts! 2013/14 Vs 2015
Replace an aluminum Upper Case Assembly compatible with the Late 2013 to Mid 2014 model A1502 MacBook Pro 13" Retina laptop. Includes the backlit keyboard and may include the trackpad and trackpad. Part #661-8154. Bild
Produkt
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly
$149.99
Replace an upper case assembly that includes the backlit keyboard compatible with the Early 2015 model A1502 MacBook Pro 13" laptop. Part #661-02361. Bild
Produkt
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly
$98.99
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
That explains everything... Thanks for the clarification. Note to self: Don't rely on the model number. Just go by the serial.
von
Out of curiosity, would switching the A1502 Trackpad over to the other device cause an issue?
von
They are very different
von
@krypticcliff screw holes in casing is different so no (2015 has holes all around the trackpad; 2013/2014 has 12 at the top)
von
Hilfreichste Antwort
Late 2013-2014 palmrest (uppercase) are compatible with each other, no difference.
A1493 is the battery model number, as long as you have an A1502 2014 (not 2015), and are trying to fit an A1502 2013 palmrest assembly, it will work fine.
Bewertung 3
1 Kommentar:
Good catch Reece!
I was so fixated on the case part I missed the point of the battery!
von
Antwort hinzufügen
jc3 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,657
