Zum Hauptinhalt wechseln
Guides and repair information for washing machines produced by Bosch, a German engineering and technology company.
21 Fragen Alle anzeigen
Stainless steel barrel loose
Stainless steel drum has come loose
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
@dionysius what model is your Bosch?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
What kind of sounds is it making?
If the sound is noticed ONLY at the end of the spin cyle:
*Thump-Thump-Thump-Thump*
This will be a worn Agitator Drive Block.
This repair requires some level of skill to correct (and possibly one specialty tool)
__________________________________
If the sounds occur DURING the spin cycle:
*Bang/Boom/Rattle/Etc*
This is most likely a tub assy that is not in it's proper position on the superstructure/frame and/or a missing suspension support spring.
To correct this--also requires a bit of previous experience being able to identifying whether or not the tub is out of position on the frame.
The rear spring however---if found hanging---is easy enough to correct with a drill unless the spring lacks a *hook* from corrosion.
Bottom line---this repair can be more than a DIYer wants to tackle. A competent servicer can resolve either fault rather quickly.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Alistair Martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 4,927
