Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz), 2,5 GHz (Turbo Boost bis zu 3,7 GHz) oder 2,8 GHz (Turbo Boost bis zu 4,0 GHz) quad-core Intel Core i7 Prozessor mit 6 MB geteiltem L3 Cache.
773 Fragen Alle anzeigen
How to fix screen flicker MacBook Pro (Retina, 15-inch, Mid 2015)?
Screen started on permaflicker yesterday. Had intermittent issues for a day or two prior. No know drops or blows to the maching. Display on external monitor is fine, screenshots do not capture any of the dipslay issues. Seems to be LCD / hardware related I think. Got tools on the way to crack into it and see if anythings loose. About 6 months out of warranty. Any other suggestions?
http://jciproof.us/7ZzzDF/lElIRHFT
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Oh Boy you got it bad!
Your issue is likely the lid assembly got a good bang damaging it. To be sure your image should be clear using an external display. If thats the case, follow this IFIXIT guide: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement and here's the part you'll need:
Or from here:
MacBook Pro 15" Retina (Mid 2015) Display Assembly Bild
Produkt
$519.99
War diese Antwort hilfreich?
Bewertung 2
Hi there! I think I have the same issue on the MacBook Pro (Retina, 13-inch, Mid 2014) and I want to see if I can fix it myself. Is there a guide for my model?
Bewertung 0
1 Kommentar:
@pavlo15914 - Here you go! MacBook Pro 13" Retina Display Mitte 2014 Displayeinheit austauschen
Here's the listing for all our guides for Mac stuff Mac so you can locate what you need for anything else.
von
Antwort hinzufügen
Curtis Baker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 57,506
