Zum Hauptinhalt wechseln
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
How to remove f(x) always showing it
in my calculator i cant find any answers because it is always showing f(x) in it
Update (10/17/2017)
in my calculator i cant find any answers because it is always showing f(x) in the screen.how can i remove it?please give an appropriate solution for this
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Press Mode at right upper side and then press 1 for COMP. Thank You!!
War diese Antwort hilfreich?
Bewertung 5
5 Kommentare:
worked amazingly ,thanks so much!
von
thanks a lot !!!
von
Would this work for a Casio Fx-85GT X ClassWiz? I don't have a MODE button? :(
von
Thank you very much, it works.
von
very effective. thank you!
von
I'd try resetting it. Removing the battery and putting it back should do this: Casio MH-10M Battery Replacement
Hope this helps!
Bewertung 2
Antwort hinzufügen
anjanakrishna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 26
Letzte 30 Tage: 131
Insgesamt: 9,556
