Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
887 Fragen Alle anzeigen
Phone is overheating after battery is replaces and Water damage
I dropped my phone in water 2 months ago and i got it repaired I replaced the battery and now it is overheating and dying quickly I don't know what is wrong with it because the guy that fixed it said I should have no more problems, anyone know why it could possibly be doing this? Also the Touch ID has stopped working.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Could be a short on the board. Do you know if when it was fixed, they cleaned the board with alcohol, or preferably ran it through an ultrasonic cleaner, with shields removed? If it wasn't cleaned or if the shields weren't removed, there could be corrosion.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
They said they ran it through an ultrasonic cleaner, they said nothing about shields though. If it's corrosion could that make my phone brake and not comeback on? Is there a way to fix corrosion?
von
You definitely want to take the shields off before putting it in the ultrasonic cleaner. Otherwise, it's like taking a bath with your clothes on still. Corrosion can definitely cause those problems, especially when the device has power sent to it.
von
Alright, I will go and ask if they will make sure the logic board and shields are good . Thanks
von
Antwort hinzufügen
Cullin Roberts wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,551
