Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Zweite Generation des WiFi iPads, erschienen am 11. März 2011. Modell Nummer A1395. Reparatur ist schwierig und verlangt Hitzezufuhr.
329 Fragen Alle anzeigen
Issues with Home and Power Button
I replaced the glass digitizer. In the process accidentally ripped off the Wifi/Bluetooth antenna. I replaced that and the glass but for some reason when I reassembled everything, the home and power button are not functional (only to turn on but not to wake or sleep). The volume and mute button still work fine.
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
when you ripped of the antenna are you sure you didnt rip anything else off
von
From what I can tell, no nothing else looks out of sorts. Would you like pictures to make sure I'm not over looking anything?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
if the volume buttons work but the power button does not you have likely torn through the cable on the top right hand corner of the iPad when letting the digitiser, it can be replaced following this guide..
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
The home button is not working either. Do you think I may have messed up something there as well? This is my first time attempting to repair an iPad. My apologies.
von
You can also turn off the lock/unlock feature by going to Settings - Display & Brightness - Then turn off Lock/Unlock. This should allow your sleep/wake button to work again.
If you want to actually fix that feature, you will need to replace the power/volume flex as rayeasom mentioned.
Bewertung 1
Antwort hinzufügen
jacob.v4 wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 39
