Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
338 Fragen Alle anzeigen
Samsung Logo appears and goes Black Screen and LED stays solid blue
This unit has been getting to me.
The initial issue was a random OS installed was causing some issues with Samsung features. He also noted that the phone would restart itself time by time for no reason.
Thinking it was no biggie, I flashed the OS with the stock OS from Samsung Switch.
I was able to back it up, restore the information, all good!
Turned it off and left it charging so his notification would not constantly ring.
Came back to turn it on. The Samsung S7 Logo appears and then black screen and solid LED Blue.
None of the manual commands work - - Power + Vol Down + Up, etc. I eventually left it alone to die and came back plugged it into the charger, works. Try to turn it on, same issue.
Is this the board causing the issue or a possible corrupted OS?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Board needed to be replace, unsure what exactly happened to it. Replacement did the work.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Does replacing the board result in the loss of all the phone data?
von
Yes, as the memory is on a memory chip the logic board on every phone.
von
Antwort hinzufügen
Juax wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 734
