Zum Hauptinhalt wechseln
pink stripes on dark background and green stripes on white background
i was playing a game when suddenly the screen turned pink. i got worried and closed down the game...and while doing so.. the screen went black as the application shut off....then there was pink color coming from all sides of the screen and stripes form and the screen from black turned pink..and on white background it shows green stripes
It has Intel(R) Pentium(R) CPU B960@2.20GHz processor
System type- is 64bit operating system x64 based processor
please help....
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
Your problem could have a number of causes and we will need to work towards excluding the unlikely ones. First, update your post with the specs of your laptop.
Now. The problem could either be the GPU that went bad because of overheating or the display cable, that could also have gone bad due to overheating.
To see which components is not working as expected, connect the laptop to an external display. If you still see the stripes on the external monitor, then it's the GPU that needs to be replaced. If not, it might be the display cable.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
von
If it were to be overheated...what do I do?
von
Antwort hinzufügen
Kizong Lama wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 414
