How can I fix a bent USB port?
Macbook Air 13" 2013. It seems like I bent the connector of the USB port on the left side, somehow. It was working fine till a couple days ago, now I tried to plug in a USB pen drive and I couldn't push it in as far as usual, and it didn't mount on the desktop.
It's as if there's something stuck inside the port, but I looked using a flashlight and the port seems unobstructed.
No idea what happened. Maybe I had something in my carry bag that pushed up against the port.
Apart from replacing the inside board, which has the USB, Magsafe and earphone jacks, is there any procedure anyone could recommend to straighten the USB connector, or check for bent pins? Is there any risk of frying something if I try to straighten the USB port pins or the white connector? The board replacement looks fairly easy, and the part isn't too expensive (around $20), so that would be a last resort.
Thanks.
Update (10/21/2017)
Okay. Here's a couple of pics, though not very good quality; sorry but I can't do any better with my smartphone camera. The part around the USB port looks a bit worse for wear, but it's always been that way, probably due to carrying it a lot in my bag. As I said, the USB port worked perfectly up until yesterday.
I also took 2 pics to show how far a USB pen drive slots into each port. The left port doesn't let my insert the pen in far enough to mount it.
Ist dies eine gute Frage?
5 Kommentare
Can you post a picture or two so we can see what happened
von Dan
Have you tried unbending and rebending it?
von Tyler Chieffo
Thanks Dan. I'll give the Magsafe port a clean.
The pics aren't very good, I know.
But the USB drive doesn't go all the way into the left USB port, as it sticks out a fraction compared to the other side. I can also wiggle it a bit side to side. Basically it doesn't go in enough on the left side to get recognized by the system, whereas the port on the right side works fine.
Looking closely at the white part of the port, on the left side it looks like it might be pushed in a fraction, compared to the one on the right. Is that possible? This would also seem consistent with the fact the USB drive doesn't insert enough to mount. Would it be safe, and possibile, to try to pull the white part out a fraction? eg. using small pliers? If there's a risk of frying something or doing more damage, then I'll look into replacing the small board, which I've found on eBay at around $20.
von Matt
i have this same problem with this same model of macbook air. the left usb port basically will only seat the first 3/4 of anything i try to plug into it. it worked fine before, and i don't see any obstructions. :(
von kim h
My left USB port got pushed in and BENT by a USB printer cable that had always worked fine, but I guess got damaged somehow.
My solution was to open the Air and remove the left USB/Magsafe/Audio board (it's pretty easy), then I carefully pried up on the USB port connector and bent it back into position. It's just a thin piece of aluminum and bends pretty easily.
The port now works fine.
von Matt
