Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
A1418 / EMC 3069 / 2017 / 3,0 GHz Quad-Core i5, 3,4 GHz Quad-Core i5 oder 3,6 GHz Quad-Core i7 Prozessor. Erscheinungsdatum: 8. Juni 2017.
98 Fragen Alle anzeigen
Add a SATA SSD to my iMac as a second HD (Already has blade SSD)
I didn't find any upgrade kit for 2017 iMacs. I know for 21.5 SSD-only iMacs, there should be a standard SATA connector at the back of the logic board, but what about the power? Which power cable should I use? Also where should I get the rubber bumper? Any help is appreciated!!
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Are you sure you want to void your warranty at this time?
von
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
Hilfreichste Antwort
I agree with @mayer - I would wait until your warranty has expired. I also think you can get a better solution externally than adding in an internal 2.5" drive.
Just so you can see how much work it is review this IFIXIT guide: iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement You'll need to get to Step61 so you can plug in the SATA & power cable on the back side of the logic board.
As far as the needed parts you can use the older 2015 SATA & power cables Apple is using the same cables here. The rubber cups are different which will be difficult to get presently.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
I cannot seem to find the right cable. The only 4 pin power cable I found promising is this one "https://www.aliexpress.com/item/Brand-NE.... Can you give me a link to the right cable? Thanks!
von
Antwort hinzufügen
Zhenfu Shi wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 101
