Zum Hauptinhalt wechseln
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 Fragen Alle anzeigen
How much is it to fixed my screen
My screen is shattered how much would it cost to get it fixed
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 16
14 Kommentare
How much is it to get my screen fixed on my zte max pro
von
My phone screen the glass part is shattered from the top left corner. How much would it cost to fix the screen?
von
How much is it to fix my screen zte max pro
von
how must do it cast to get my phone screen fix
von
How my will my zte phonecist to fix the screen
von
9 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If you wanted to repair the phone your self, the display assembly is around $30-35 USD.
It would likely be $20-$40 labor for a shop to do it.
https://www.ebay.com/sch/i.html?_from=R4...
War diese Antwort hilfreich?
Bewertung 9
4 Kommentare:
My phone cracked up
von
It's easy to change the screen. Buy the screen and I'll change the screen for u for free.
von
Can you walk someone thru the repair via webchat?
von
How much is zte phone screen model Z982
von
Buy oem screen on eBay 28 bux, prolly 20 labor from "pro..." Or YouTube that ish yourself.
Bewertung 3
1 Kommentar:
My phone drop in to water and the screen blank out
von
They are many places where you can get a display dependent on your location. See the guide below.
ZTE ZMax Pro Display Assembly Replacement
Bewertung 3
Antwort hinzufügen
Azea Brown wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 15,223
