Zum Hauptinhalt wechseln
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
33 Fragen Alle anzeigen
Where is my MAP Sensor located and how do I get to it?
I'm looking for my MAP Sensor on My '02 Jeep Liberty 3.7L. How do I get to it and Remove it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
I own a 2012 Jeep patriot 2.4 engine can you please help me to find my Map sensor!? Thanks very much
von
I put a 2007 3.7 jeep liberty engine in a 2008 jeep liberty limited and have plug in harness that I can't figure out where it goes
von
above comment about 07 3.7L into 08, are they still the same engine? just wondering myself I have 06 I thought or I know body style was changed in '08 but did they keep the same engines which out anything might be why you can't figure out the harness
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Mariah Sklaney check at the front of the intake manifold
3.7L
The Manifold Absolute Pressure (MAP) sensor is mounted into the front of the intake manifold (Fig.18). An o-ring is used to seal the sensor to the intake manifold (Fig. 19).
(1) Disconnect electrical connector at sensor.
(2) Clean area around MAP sensor.
(3) Remove 2 sensor mounting screws.
(4) Remove MAP sensor from intake manifold.
(5) Check condition of sensor o-ring (Fig. 19).
INSTALLATION
The Manifold Absolute Pressure (MAP) sensor is mounted into the front of the intake manifold (Fig. 18). An o-ring is used to seal the sensor to the intake manifold (Fig. 19).
(1) Clean MAP sensor mounting hole at intake manifold.
(2) Check MAP sensor o-ring seal for cuts or tears.
(3) Position sensor into manifold.
(4) Install MAP sensor mounting bolts (screws). Tighten screws to 3 N·m (25 in. lbs.) torque.
(5) Connect electrical connector.
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
The part is extremely hard to get to. The sensor broke in half while trying to remove the housing to get to the Thermostat sensor. It’s as if you need a special size tool to remove the bolts. Any advice on how I can remove the old sensor?
von
Hi Wendy. I replacement my MAP sensor and found that by removing the plastic box on top of the engine really helps. This will allow you to have better access to the part. I have seen a few posts about replacing the MAP sensor and NO ONE says to use a 7 mm socket or wrench! None of my one-quarter rachets would fit into the very small space to remove the left side 7 mm hex head screw. The RH side of the part, I removed with a 7 mm box wrench. I went to Autozone and found a "mini rachet" that is one quarter inch drive. The total length is 3.5 inches but the head of the rachet is only 5/8 in wide and only 1/2 thick. Got home and it just fit into the confined space and I was able to remove the bolt. I hope this helps somebody out there.......Hal from Bradner OH
von
Does anybody know the size of the bolt. Wanted to change the MAP sensor and I see a bolt is missing on the right side.
von
This Guy is right on where the Map sensor is on your Jeep.He shows a Picture of the location also!>>>>>>>>>... oldturkey03 @oldturkey03
Rep: 724.2k
POSTED: OCT 24, 2017
OPTIONS
Bewertung 1
Antwort hinzufügen
Mariah Sklaney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 67
Letzte 30 Tage: 290
Insgesamt: 23,604
