Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Correct Battery APN# for a iPhone 5s
I'm on the process of changing my old battery on my phone (APN: 616-0720). I would like to know if there is any concerns about using a replacement battery with a different APN (616-0718).
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, it will work
War diese Antwort hilfreich?
Bewertung 2
Should work fine. My iPhone 5s battery APNs are currently: 616-0721. I think batteries between 0718 and 0721 should work fine.
I think the only thing to worry about is if the battery has the right connector and mAh capacity.
Bewertung 1
5 Kommentare:
Ok, I think I'm just a little parano since the last battery I bought has some problems with the % gauge
von
Those issues usually occur from cheap aftermarket batteries or refurbished ones.
von
You're probably right. I've managed to get a new battery (616-0728) and everything is working fine now !
von
My iPhone 5s current APN 616-0722 upon replacement using APN 616-0728 become worst performance ( always restart after few minutes).
von
Random reboot after battery replacement generally points to pry damage above the battery connector.
Above the battery connector has 4 little smd components and the third one counting from the left is crucial as if this damaged or missing you'll get the symptoms as said above.
You'll need to get the component replaced via someone that does micro-soldering if that is the case.
von
Antwort hinzufügen
Francois Thibault wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,612
