Power: adapter or convertor?
Hi all,
I recently moved to Hong Kong and i have taken my PS4 Pro with me. However, I am sceptical about plugging it in (with an adapter) in case it causes a problem, breaks, smokes or whatever.
As far as I'm aware Hong kong is similar to the UK and has 240 V and 50hz. The 'power' in the PS4 Pro guide is stipulated between '100-240 V AC, 50/60HZ', so to my understanding an adapter should be fine...
I am just wondering if anyone else has any information on using an American PS4 Pro in Hong Kong? If a simple 'travel' adapter would suffice to play the console, or if i have to go the whole hog and purchase voltage convertor of Amzaon or something.
I thank you for your time and replies.
Ist dies eine gute Frage?
1 Kommentar
I don't know about adapters/converters, etc., but you might see if a local repair/electronics shop has the equivalent power cable to the one the PS4 came with. Considering you moved there, it might be worth it/cheap.
Here's another discussion on this topic, in case you haven't seen it: Is the power supply dual voltage?.
von Rachel Acosta
