Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Why is my screen bulging on the left side of the case?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes it more than likely is a swollen battery. If you have a replacement battery, open the device with the proper tools and after you unhook the battery and LCD, check the battery for its size and shape. If the phone is laying flat on a desk, get down to phone level and look at it and see if you notice it protruding higher on that side than the other. If it is the battery and you replace it, the LCD will sit properly in the phone again and will look normal.
Hope this helps :)
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
what would make my iphone 6 replacement battery swell?
von
Same comment for me. I replaced my iPhone 6 battery and all was great. Until about a month after (this past weekend) and the bulging battery has made my screen push out. And I get intermittent reboots. Crap.
von
it could make it swell from over use, becoming hot or being old.
von
Would it be okay if I'd keep my swollen
phone for another year?
von
Hilfreichste Antwort
Most likely is a bad swollen battery. Here's how to replace it: iPhone 6 Akku tauschen
Bewertung 2
Antwort hinzufügen
Chris Perkins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 19,575
