Phone stuck in restoration (shows support.apple.com/iPhone/restore)
There's really not much to add. I actually bought this phone for the parts, but figured I could have a go at fixing it.
Turned it on the first time and it showed the usual startup configuration screen. Was going through it fine, but then the phone shut itself off and started showing the itunes logo and the charging cable. So I plug it in and restore it. Then I'm faced with the same screen, except on the top it says :
support.apple.com/iphone/restore
With every restore attempt, I'm stuck with this screen.
As expected, apple's webpage is worthless in solving the problem, so I was wondering if perhaps anyone has experienced the same issue and know of a solution.
Thanks in advance.
Hope the pics ain't too bad.
Ist dies eine gute Frage?
3 Kommentare
may I ask if you fixed this problem? I'm currently having the same problem with my iphone 5. I have my iphone 6s working after restoration, but apparently my iphone 5 got stuck. please let me know if you found a solution for this problem. thank you!
von gerlyn_galura
hola amigo tengo el mismo problema, no pude solucionarlo... y el equipo estaba funcionando lo unico que ise es restaurarloen itunes y se quedo asi¡
von angelo
I never fixed this problem. Ended up selling for parts.
von Smeargle
