My phone fell down and now the screen is dark I can't see anything or
My phone fell down and now the screen is dark I can't see or type anything, what do I do?
Ist dies eine gute Frage?
Gloria ,check your battery by removing the back cover. Remove the battery from the phone , inspect it for damage such as swelling leaking or other obvious signs of damage . If all is well reinstall it try powering on the phone and listen for the startup chimes and the vibration that usually accompanies the start up. If all this is good and you hear it staring up then the problem is with the LCD it will need to be replaced . You can purchase new screens and on ebay or amazon or here from ifixit
This video will guide you through the process
https://www.youtube.com/watch?v=ef2Oahpa...
If you dont get the startup chimes or any indication its starting up there is more serious damage done. If this is the case then contact use again and we can help from there. It is most likely the LCD will need to be replaced. Hope this helps
War diese Antwort hilfreich?
سلام صفحه نمایش گوشیهای لمسی جدید بسیار به ضربه حساس میباشند وتصویر انها از بین میرود شما حتا اگر کسی به تلفن شما زنگ بزند تلفن شما زنگ میخورد اما تصویر ندارد شکستگیهای خیلی کوچک درصفحه نمایش تلفن به وجود ماید که با چشم به سختی قابل مشاهده است وتنها راه حل این مشکل سپردن تلفن به تعمیرگاهای مجاز برای عوض کردن صفحه نمایش تلفن میباشد سوال دیگری داشتید با من تماس بگیریدamirslamefar@gmail.com
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 2,144
1 Kommentar
Hi i have this problome to with my phone . You should try looking at the battery of the phone to see if ther is damge on it
von Ross Clark Teilen
