Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und zum Zerlegen von Handys aller Hersteller und Service-Anbieter, inklusive Apple iPhone und Samsung Galaxy. Alles, was du brauchst, um dein Handy selbst zu reparieren.
73388 Fragen Alle anzeigen
What is the best way to heat up batteries for removal?
I currently watch all the tear downs and I see people use heat guns or the IOpener and i am wondering how long do you leave the Iopener on screens before they are damaged and also when warming up batteries to be removed due to adhesive is it wise to use heat and what is the best way to go about it ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
if its an iphone i usually blow a hair dryer on the back of the phone
von
And this doesn't damage anything? Always thought applying heat to a battery was a no no.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I don't think anyone ever quantified how much heat is necessary. An iOpener, or similar magic bag, will probably get to ~60-65C. Depending on the device, you want to transfer enough heat untill the device is uncomfortably hot to the touch but will obviously be below 65C. I personally use a heat pad and set the temperature to ~70C and leave the device until I think the entire device is at that temperature, or close enough. If the heat is too high or the device left on the heat pad for too long, you may damage the LCD (this applies more to an iPad).
I don't think you can damage a device with an iOpener or hair dryer. If you use a heat gun, watch out because they can throw a lot of heat very quickly.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So you would recommend a heat pad for screen removals? also how do you get out batteries that have adhesive to them ?
von
The heat pad is essential for iPads and very practical for applying heat to any other device. The batteries have pull tab adhesive so that is the first option. If the tabs break, sometimes you can still grab them underneath the battery. When you can't, you have to apply heat and gently pry them (no pressure on the logic board though).
Thanks!
von
Antwort hinzufügen
A kerr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 20
Letzte 30 Tage: 61
Insgesamt: 2,377
