Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 32 GB 2017
sorry for my english, please reply or iphone 6 32GB made in 2017 have a fix problem with touch dissease, or it's still the same iphone as in 2014. Thanks for the reply
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Any iPhone 6 and iPhone 6 plus is prone to touch disease.
War diese Antwort hilfreich?
Bewertung 2
The current theory is putting the phone into your back pocket and sitting on the phone is the root issue. The phone flexes and over time the connections snap within the logic board. Here's more: A Design Defect Is Breaking a Ton of iPhone 6 Pluses
I can say I've not encountered any issue with my iPhone 6 as I place it in my front pocket. Most woman place it in their back pocket and from my friends who work on iPhones more woman have this problem then men! So I suspect this is a good clue!
The newer iPhone 7 & 7+ use a stronger alloy of aluminum and the newest iPhone 8, 8+ and X all use a steel plate covered with glass and aluminum for the sides. Also the iPhone 6s & 6s + had a redesign so the touch logic was moved to the back of the display which is a safer place from stress.
So far I haven't heard any reports of Touch Disease on any of these newer iPhones.
Bewertung 2
4 Kommentare:
Thank you for your response, I secretly hope that as long as my iphone 6 32GB is made in 2017 so apple have repaired problematic place on board
von
If bending of the phone is the cause, simply get a harder case.
von
I was just wondering if apple had some sort of boot on these models 32GB made in year 2017 ... somewhere I figured that apple removed the boot on iphone 6 made after November 2015
von
What do you mean by boot?
von
If your phone has weird gray lines, or you can’t interact with the screen, touch disease is likely, even if it was made recently.
Bewertung 0
2 Kommentare:
Sorry for my english i will speak, I thought that the apple in the model made in 2017 would have repairs ... tightening the mather board
von
They probably didn’t change it
von
Antwort hinzufügen
Tomas Ohnuvzdornx wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 158
